Improvise
Rich Swatton_2
Member Posts: 24
Who knew Makita made pumps?!
Yours, Larry0 -
Love it! Did you get that from Amazon? Seems you can get pretty much anything there...Br. Jamie, osb
Red Green would be so proud!0
Check out the website thereifixedit.com
It is full of stuff like that. Mostly shake your head kind of stuff, but some good ones. Good for wasting time on the internet though.
Rick0 -
Would've been better if most of the vent holes on the drill were open and it wasn't taped to something combustible. Looks like 90% of the vents on the drill are blocked.
I've had one of those drills for 25 years and I'm starting to believe it may actually be indestructible.0
I worked for Bosch as a repair mechanic and I repaired many manytools guys thought were indestructible.SWEI said:I've had one of those drills for 25 years and I'm starting to believe it may actually be indestructible.
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
