Viessman Paromat-Duplex cutting out and local engineer useless
philsmith
Member Posts: 4
in Oil Heating
Hi all, what a useful forum!
I hope someone can help. I have a Viessman Paromat-Duplex oil boiler in my place in France with a Trimatik MC controller.
The boiler cuts out emitting a small amount of unburnt oil smoke at the same time and requires resetting (safety switch) numerous times while warming up, once it has reached temperature it operates as it should cutting in and out on its own and maintaining temperature without issue.
The local engineer seems disinterested (rural France leaves me little choice of who attends) and I was hoping to have some areas to explore with him to get somewhere.
I've asked numerous times if the flue may be blocked causing the reset through exhaust pressure and he has said no. The flue goes in to an old chimney breast but another room with a blocked up fire place on the same chimney smelt of exhaust fumes the other day indicating the exhaust gases weren't escaping the chimney but filling the chimney void.
If the boiler has been left overnight it will stay running without cutting out for the longest, once it has been running it is very little time between resets. Once at temperature it runs for 2 minutes and stays off for about 10.
Would this indicate a blocked flue and cut out due to exhaust pressure? The exhaust gases and subsequent pressure clearing overnight (allowing longest continuous running in the morning), building up once running and requiring resets and then clearing enough to stay running on and off in short bursts to maintain temperature?
Or am I looking at a separate problem (blocked flue) and the cutting out issue is something else?
Apologies for long winded and poor technical info explanation but I'm pulling my hair out with an engineer who wants to be here for 10 minutes, say it's fixed and leave who doesn't seem interested in exploring other avenues.
Do you have an English product manual you can post?
If it is cutting out on safeties regularly, it is running in an unsafe condition."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
Sadly not, I'm looking for an English language manual0
You may be able to browse there North American lineup and find the same product under a different name."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
I don't know of any North American oil fired units that have thermal safety cutouts. Might chimney be in need of cleaning?
A few pics of unit may be of help.0 -
Hi, yes the primary control is in safety which requires a minute before it can be reset. I'm getting the chimney swept as we speak and shall see what happens after that, the engineer says it's nothing to do with the chimney and to replace the boiler so I shall have to push other avenues myself.0
- 119 Chimneys & Flues
- 116 Geothermal
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
