3/8" two hole pipe clip
archibald tuttle
Member Posts: 1,196
thats what i would call it. some would call it pipe clamp. i'm looking for a plastic flat style pipe clip for tubing size. so regular 1/2" and 3/4" nom (5/8 and 7/8 OD) are readily available. but 3/8" (1/2" OD)f. Being one of those odd ducks who prefers 3/8" in many circumstances I find that the industry has all but abandoned this size that has so much promise, tighter radius. smaller holes drilled through stuff. i get that the tubing isn't cheaper than 1/2" and doesn't carry as much btus or deliver as much volume at pressure but i find many circumstances where it is useful. i can get the less robust one hole clips, but i'm looking for the heavier two hole style if anyone has ever seen any. thanks, brian
How about 3/8 BX one holers? Use them all the time0
for copper? Or pex? Like Bob,I use either single or two hole EMT conduit straps, galv steel or plastic. If the copper sweats you need to insulate to prevent corrosion between the galv and copper, or use plastic straps.Bob "hot rod" Rohr
Living the hydronic dream1 -
Sioux Chief 501-10
thanks for the ideas,
i'm familiar with the single hole BX clips. and the copper coated 501-1 style. that may be my goto here although i would have preferred a 559-1, i.e. the 1/2" OD size of this clip http://www.siouxchief.com/products/support/supply-hangers/plastic-cts/tube-hangers/ezglide-tube-clamp
the sioux chief plastic ezglide style two hole clamp which is a CTS style that i use for both copper and pex.
i do sometimes use the single hole plastic style and i used several of those offsetting in this case (actually wasn't pipe but a three stem show valve that i wanted to secure to plywood on the back side of the shower enclosure. those metal clips would have been OK but prefer plastic rather than coated steel but don't think there would have been a callback in my lifetime.
still, it was another chance to vent that the lack of full support for 3/8" piping means people don't use it which means manufacturers don't support it. (i had to bend over double to find a 550-M1 , i.e. 3/8" bend support . . . not to mention how many months salary you gotta unload to get a Veiga 46001 or 46002 (3/8 pex x 3/8" comp. straight and angle stops respectively).
but i can't complain about the veiga price targets on those cause i haven't even found any other manufacturer supporting 3/8 stop valves.
maybe we can have a meeting of the 3/8" 12-step group at AHR this winter. even if they kick us out as homeless, orlando ain't so bad at that time of year.
- 50 Industry Classes
