Not in Dan's EDR book...
Steve Minnich
Steve Minnich Member Posts: 2,868
or anyone else's either. I pulled a radiator cover today and behind the disconnected cast iron radiator, I found this piped in. I kid you not. I'm keeping it for my trophy room.
Steve Minnich
  • Harvey Ramer
    Harvey Ramer Member Posts: 2,281
    It would be interesting to know what the installer's reasoning was.
  • Steve Minnich
    Well I know one of the reasons. The bottom of the cast iron radiator had epoxy in 3 different spots between sections. What I don't understand is that he or she was trying to heat a 400sf room with 2 large windows and 20' of exposed wall with no insulation with some copper pipe.
    Steve Minnich
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,686
    Who gets to work in America? Everybody!
    Retired and loving it.
    ChrisJCharlie from wmass
  • Harvey Ramer
    Yeah, that's kind of like trying illuminate a parking lot with a candle. I'm guessing either a diy or a knucklehead.
  • Steve Minnich
    Tim was going to cut up the copper and put it in our scrap can and I said no chance, we're keeping that. Forever. Finding that bit of creativity made me smile.
    Steve Minnich
  • Harvey Ramer
    It would make a decent towel drying rack.
    It's fun finding stuff like this.
    Steve Minnichjonny88Charlie from wmassZman
  • DanHolohan
    Stephen, mount it on the front of your truck. It will whistle at 30 mph.
    Steve Minnich
  • ChrisJ
    ChrisJ Member Posts: 17,068
    I'd love a steam heated towel rack in the bathroom. I'll have one too if I ever tear open the downstair's bathroom ceiling to run piping. :p
    Need plated copper pipe though, bare copper is just tacky.
  • Rich_49
    Rich_49 Member Posts: 2,785
    Bare copper is doable if you clear coat it .
    732-751-1560
    Rich McGrath 732-581-3833
  • ChrisJ
    There's a clear coat that will withstand steam for years?
  • Rich_49
    Not sure anyone said it was steam . But I would imagine that some cars located in hotter areas than Nj reach temps approaching what a steam rad does . So, maybe .
    732-751-1560
  • ChrisJ
    Not sure anyone said it was steam!?!?
    You really don't know me do you Rich. Steam is a given!
    Not to mention the one in the picture has a trap on it.
  • ProblemSolver
    ProblemSolver Member Posts: 190
    Use it as your icon picture.
  • unclejohn
    unclejohn Member Posts: 1,833
    I once made a evaporator for a large 3 door reach in out of 3/8 copper pipe, no fins. I then made a drain pan with staggered sheet metal so water would drip from one to the other like a slinky going down steps into a pan with a drain. The old coils would get eaten up by the salad dressings in the box. It didn't work well until I added a couple of Acme fans, my first thought was that the cold air would just fall and create enough circulation. The fans did the trick. Trouble was nobody got to see my genius at work, the coil was never again replaced and was operating when the old Roma Restaurant closed.
  • unclejohn
    The reducing coupling right before the trap means there is always about a pint of water in the pipe at all times. Must have sounded like a rain storm all night long.
  • Fred
    Fred Member Posts: 8,542
    It almost looks like they designed it that way? Reduced to 1/2" and then back to 3/4". @Stephen Minnich are there any pin holes in the top of those copper runs? Do you think that was someone's ingenious idea for adding more humidity to the house and maybe that room got enough heat from other radiators? It just doesn't make sense???
  • Rich_49
    Pardon me Chris . certainly did not look too closely at the picture . Steam for sure
    732-751-1560
    ChrisJ
  • Steve Minnich
    Just my opinion but anything that looks like an ingenious design here was strictly by accident based on the history of the hydronic work in this church.
    Steve Minnich
  • Abracadabra
    Even monkeys can write a novel once in a million tries right?
    Steve Minnich
