Fan in a Can questions
itzasean
Member Posts: 71
So I have a 2 family home with 2 gas boilers (one steam one forced hotwater) and 2 Gas hotwater heaters. This is very common in my area. The basements are around 35x30x7. I have been in so many of these houses yet none have any extra source of air like "fan in a Can". Was it not so common 20 years ago? Also do fan in a cans ever drop the basement temperature you can freeze the water pipes?
Chances are you don't need one... the use to which I think you are referring is the use of a "fan in a can" (what a name!) to bring in enough combustion air for the boilers. If the structure is sufficiently draughty, there is no need for one!
However... in houses which are really tight (whether originally or due to renovations) one may well be required.Br. Jamie, osb
Is there any way to test to make sure its safe?0
What's the total BTU's of all the appliances, and which ones use the room air for combustion air?
