touched wires together while changing thermostat
sashasenkoff
Member Posts: 4
I was installing a NEST thermostat. I didn't kill the power and touched the wires together. Now that radiant zone won't work. Is the problem in the zone valve? Maybe the end switch? Or a fuse in the furnace? Thanks!
Man thanks!0
How many wires did you have at the thermostat end? If just 2, shouldn't have blown anything. If more than 2 then yeah, you probably let the magic smoke out of something....
METhere was an error rendering this rich post.
It was only 2. 1 red and I white. Where would you start? Open the furnace and look for fuses? It's radiant heat so it takes a while to heat. I put the heat up to 70 one night and it didn't go past 63. The furnace was installed in 1996. Could it burn out a zone valve as opposed to a fuse? As you can see I know very little about this kind of thing...0
If it's just two wires -- red and white -- and that's all you have hooked up to the Nest... it's not going to work. The red and white need to be hooked up to something which is going to close the circuit when heat is needed. Just a switch. As Unclejohn said, just try hooking those two wires -- at the thermostat -- together and seeing if you get heat.
If I recall, a Nest -- among other idiosyncracies -- must have a dedicated C lead -- 24 volts AC always on to operate at all.
You really have two choices -- something a less next generation and golly gee whiz, like a good programmable thermostat -- or pull a third wire for your Nest.Br. Jamie, osb
Like all web-enabled thermostats, it has a power budget that's just not quite workable on batteries. They claim it can power steal, but IIRC actually doing do causes it to do something ugly (reboot, perhaps?)Jamie Hall said:If I recall, a Nest -- among other idiosyncracies -- must have a dedicated C lead -- 24 volts AC always on to operate at all.
Isn't "shorting" the red and white together how you turn the heat on? Literally?
The Nest claims it doesn't need a Common, but everything I've heard says it really should require one. For example, a really long call for heat can kill it's internal batteries.
And............ I just noticed SWEI said the same thing.Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment1 -
Thanks guys, I'll try to touch the wires together and see if I get heat. Thanks!!0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
