Pinnacle v.s. Munchkin
boilermate
Member Posts: 4
in Gas Heating
I'm working on a Pinnacle PI-80 that has a dead blower motor. I've swapped out the control board to no result (fault code F-13). I want to confirm with you guys who have more experience with this Pinnacle series, that parts are basically interchangeable between the PI-80 and the essentially similar Munchkin 80M. Is the Munchkin blower - part #7250-085 a direct replacement for the Peerless blower - part #91546? Since the Munchkin part is available for about 1/3 the cost of the Peerless part, there is a lot of $$ to be saved by going with the 80M part!
You need to contact either Peerless or HTP for the answer to that. I do not have the two I & O manuals handy or I would look it up.0
I think it's worth the gamble with that cost difference. Same boiler, different tag.0
Pinnacle is re-labelled HTP. I agree with wcs.0
I would be careful when dealing with electronic boards as they can have the very slightest difference and yet still look the same. As stated I would check with manufacturers.0
