Tappings or fittings
I'm only getting "domestic " pipe and nipples now, was using domestic fittings from the beginning, but an now all domestic.
Ward fittings look real nice and are available almost anywhere. I've used Anvil too, a little rougher looking but a good fitting. IMO Anvil makes the best unions.DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
Specializing in Steam Heating, Serving the residents of New Jersey
https://heatinghelp.com/find-a-contractor/detail/dl-mechanical-llc
https://m.facebook.com/DL-Mechanical-LLC-315309995326627/?ref=content_filter
I cannot force people to spend money, I can only suggest how to spend it wisely.......1 -
Does any one reuse NG pipe on a change out?0
Domestic all way, I cant tell you how many times Ive had issues with imported pipe and fittings.
I prefer to replace the gas piping when im replacing the boiler. most of the time the existing gas piping is a mess too almost as bad as the near boiler piping.0 -
The short answer is, it depends. On the size, condition etc.JUGHNE said:Does any one reuse NG pipe on a change out?
Consulting0 -
Well bottom line those are ward fittings and American made boiler....I hope both companies continue to pat themselves on the back at the company trips and golf outings for there great profits...They cut back on quality control, because it effects there bottom line. Jmo0
I think the tapping into the boiler is off a bit. Not so easy to run a tap into cast iron perfectly plumb. The longer the nipple into the tapping the more noticeable the error.
Water heaters are the same way, especially the side taps.Bob "hot rod" Rohr
Living the hydronic dream1 -
Is that cardboard I see protecting the new appliance from oily sharp fittings, tools etc?
This is part of the reason I gave in and bought a 65R-TC. I'm a homeowner, I shouldn't need a $900 manual threader but apparently, if you're going to try and pipe radiators to an existing main you have no choice. Between fittings being threaded slightly different and everyone threading pipes slightly different I found it near impossible to get things to lineup unless I did it my self. Doing it my self, sometimes I need to try a second time but 9 times out of 10 I nail it. For most piping, like running my NG I had no issues with stuff being a little off from places threading it for me, but for anything needing to lineup with an existing pipe and a hole in the floor forget it.
A local place near me threads pipe so it starts to bind a little on the last thread! Doesn't matter what fitting you use, their threads are too loose. I even asked the guy last time I bought from him not to thread so deep because they're too loose. Got the same results and he told me to use wicking to makeup for it because it's my fitting's fault.
I am sure you already know because you seem very involved...A screwd fitting should go in 3.5 to 4 turns by hand. Any more or less can cause issues...II don't think it's to much to ask manufactures to get it right...I was pissed at that boiler to see the offset... Btjm0
It's not too much to ask but apparently it's not going to happen.j a said:I am sure you already know because you seem very involved...A screwd fitting should go in 3.5 to 4 turns by hand. Any more or less can cause issues...II don't think it's to much to ask manufactures to get it right...I was pissed at that boiler to see the offset... Btjm
I learned the hard way very early on no one seems to follow the actual rules to NPT.
http://www.piping-designer.com/National_Pipe_Thread
For a 2" NPT fitting in a perfect world you should get 5 hand turns and 3 wrench turns.
This is another reason I'll never use a Chinese fitting again. Nothing like having it screw on 1 turn or 2 turns by hand and then bind up quick.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Just curious, why do some of the nipples have only PTFE tape and others only dope? I generally do 3 wraps of PTFE tape and a little dope on top to help lubricate it. If it's a really good thread and fitting I'll often just use dope.
I have a manual/book given to me many years ago...the U S Navy shipbuildig and pipe fitting book/manual...its awsome... I used the charts and info for many years...actually I have 2 copies0
When I piped out of boiler connections with copper, I would heat and soften the tube near the boiler connection and bent it slightly to get it plumb from all directions.
Or start out with swing ells at the connection, if it is a side connection.Bob "hot rod" Rohr
Johnny 88 figured you would be on the same page...I was beyond pissed and expressed my thoughts to the manufactures... I am sure they could care less0
Hot rod this was a steam boiler...refer to the pic..copper is a no no and with steam we like high risers...There is no excuse for the poor quality of the manufactures...0
Understood about the steam, and steel pipe. I was just sharing my method of dealing with off kilter tappings, when piping HW boilers in copper.j a said:Hot rod this was a steam boiler...refer to the pic..copper is a no no and with steam we like high risers...There is no excuse for the poor quality of the manufactures...
Sounds like bob uses similar method on steel pipe for tweaking.Bob "hot rod" Rohr
Yes there are a lot of great people working for the company's out here...its the company's that I don't like...there interested only in the bottom line...like I said they celebrate sales while we fix the crappy crap they produce...band new out of the crate...0
- 116 Geothermal
