Utica Install
Aaron_in_Maine
Member Posts: 315
Just finished this install. Took out a Slant Fin Liberty oil boiler.
2
nice clean install. i wouldve used the Alpha pump on the system.0
What's the story with the T handle style ball valves? Is there any benefit to them?
I'm asking because I have a friend that was going on and on about them the other day and I've never seen one until these pictures.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
The only benefit I know of is that they can save a lot of space when your piping is tight. They don't swing out as wide and prevent the need to cut a long traditional handle short in order to turn it on and off properly.ChrisJ said:What's the story with the T handle style ball valves? Is there any benefit to them?
I'm asking because I have a friend that was going on and on about them the other day and I've never seen one until these pictures.2 -
They are flanged ball valves. They take up less space and make it simple to change out a pump.Ross said:
I'm asking because I have a friend that was going on and on about them the other day and I've never seen one until these pictures.3 -
Nice work, as usual!!Aaron_in_Maine said:Just finished this install. Took out a Slant Fin Liberty oil boiler.
2 -
Hi Aaron, beautiful install, so nice and neat. Why do you transition from copper to black pipe? Why not make all of the piping in copper? Is there a benefit?0
- 19 Recall Announcements
