Burnham Series 2 Model B Gas heater model # is 205NIL -GEI2
Rawle
Member Posts: 2
in Gas Heating
we just bought a home that has a Burnham Series 2 Model B Gas heater model # is 205NIL -GEI2 with a old Honeywell thermostat. i tried following the directions on how to light the pilot
it came on once and shut off after about a minute.
i took off the cover
turn off the power switch at the side of the panel
turn the black switch to OFF
wait 5 minutes
Turn the switch ON and the power switch on the panel ON
turn the thermostat all the way up but still it won't light.
Any help would be greatly appreciated
wait 5 minutes
You have a spark ignited boiler. Do you hear the igniter sparking when you turn it on? If not have you checked to see if you have power to the boiler, make sure switches are in the on position, make sure you do not have a stairway switch shut off, check circuit breaker.0
ok guys its fixed, it was so cold last night i had to get somebody to look at it, for $125.00 they came and turned on the water that was the problem
