Knight Boiler Igniter issue....
Boring
Member Posts: 48
Last year while servicing my boiler, when I pulled the plug off the igniter the inside of the igniter came loose from the ceramic surround---replaced the igniter. This year the same thing.... Is there a bad bunch of igniters out there, or is this a common issue?
Must be a bad batch. That shouldn't happen.Bob Boan
You can choose to do what you want, but you cannot choose the consequences.0
