Fixing Bad Radiant
Paul Pollets
Member Posts: 3,668
Attached is the fix for the open system that wouldn't heat the home or provide proper DHW. The Vitodens 222F cabinet model has a small footprint and a built-in 30g DHW SS tank. We used a larger FPHX to take the place of the low loss header. Pic 2 is the original system.
2
The Alpha looks completely out of place on the old job. : )
Awesome work.Steve Minnich0 -
Paul,
That looks great well done.Tom
Montpelier Vt0 -
Who's expansion tank bracket is that Paul , Dutchtech ?You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38330 -
Beautiful job (as usual.) I suspect you have another customer for life.0
Beautiful work as always. What was the problem with the old Uponor tubing that it needed to be replaced? Was it in floor or panel rads?0
- 110 Chimneys & Flues
- 981 Plumbing
- 387 Solar
