Fixing Bad Radiant
Paul Pollets
Paul Pollets Member Posts: 3,671
Attached is the fix for the open system that wouldn't heat the home or provide proper DHW. The Vitodens 222F cabinet model has a small footprint and a built-in 30g DHW SS tank. We used a larger FPHX to take the place of the low loss header. Pic 2 is the original system.
Bob Bona_4Zman
  • Steve Minnich
    Steve Minnich Member Posts: 2,868
    The Alpha looks completely out of place on the old job. : )
    Awesome work.
    Steve Minnich
  • Tom_133
    Tom_133 Member Posts: 956
    Paul,
    That looks great well done.
    Tom
    Montpelier Vt
  • Rich_49
    Rich_49 Member Posts: 2,785
    Who's expansion tank bracket is that Paul , Dutchtech ?
    732-751-1560
    Rich McGrath 732-581-3833
  • Paul Pollets
    Thanks. Flamco tank brackets. They make both non-potable and SS for potable. I found a neoprene insulation jacket made for FPHX's which will be installed. The exchanger puts out a lot of heat.
    Rich_49Canucker
  • SWEI
    SWEI Member Posts: 7,348
    Beautiful job (as usual.) I suspect you have another customer for life.
  • RobG
    RobG Member Posts: 1,844
    Beautiful work as always. What was the problem with the old Uponor tubing that it needed to be replaced? Was it in floor or panel rads?
