probe type LWC, still common?
hot_rod
Member Posts: 26,602
or do the low pressure switches installed in most mod cons pass AHJ inspections for protection?
Pressure switches pass muster here in NM. Given the amount of safety features overall in modern boilers, I trust them.0
Same here in CT. In the early days inspectors weren't up on integral LWC's, today it's no problem.0
In Colorado the state inspectors are requiring separate LWC's on commercial. For residential, it varies by jurisdiction locally there is no requirement at all."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
That's true in CT. Commercial they want seperate, just like redundant pressuretrols0
Michigan requiring low water cut offs in both residential and commercial.0
Separate LWCO in NY0
Last I knew the pressure switches past here in Maine.
Seperate in NYC ,NY state varies.Once you explain the operation of boiler to inspector they pass in my experience but that does not apply to NYC .0
