Boiler Best Practices
Any suggestions for removing the draw rods? WMC tech support said there's 2 set on the EGH-85 we're taking out. If we get our new boiler ourselves, suggestions on bringing it down the stairs? Maybe get a heavy duty hand-truck or something else? Can we store it in the box in our basement for a few days before the install begins, or does it need to be opened-up right away after shipping arival?0
Your 100% correct, on push nipple boilers its a b****, on the modern Weil McLains with the elastemer seals, they come appart easily.JUGHNE said:Dave, your last posting really made that removal sound easy.
My experiences were never that way.
The way things went for me was that nothing fell apart, (40 to 50 year old boilers) I used log splitting wedges to split the sections apart. Pound them in with 2 pound sledge, they would fly out heading for your head. It was like wrestling a cast iron pig; and eventually you realize the pig enjoyed it.
Safety glasses, boots and heavy gloves seemed appropriate for the job.
And these were smaller boilers. Each section seems like a 100 pounds. (they were only 60) Someone suggested laying down old tires to keep from breaking the concrete floor. (Probably a good idea for larger sections.)
And for this it would weight up to $45-50 at the yard.DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
Specializing in Steam Heating, Serving the residents of New Jersey
https://heatinghelp.com/find-a-contractor/detail/dl-mechanical-llc
https://m.facebook.com/DL-Mechanical-LLC-315309995326627/?ref=content_filter
I cannot force people to spend money, I can only suggest how to spend it wisely.......0 -
Thanks Dave, now I don't feel like a 220 pound wimp anymore
Yes these were push nipples, the draw rods were not even tight.
I would suggest a sawzall to just cut the rods and don't stand in the wrong place if it falls apart. Lucky for you.
Note: so does this say something about the durability and longevity of sealing methodology between CI sections?0 -
I don't know what kind of basement stairs you have but I doubt you'll be able to get it into the basement, in the box. Probably have to take it down to bare boiler block.cubicacres said:Any suggestions for removing the draw rods? WMC tech support said there's 2 set on the EGH-85 we're taking out. If we get our new boiler ourselves, suggestions on bringing it down the stairs? Maybe get a heavy duty hand-truck or something else? Can we store it in the box in our basement for a few days before the install begins, or does it need to be opened-up right away after shipping arival?
We can use the backyard trap door with the concrete steps that has one 90 degree right turn at the middle landing, then another left at the base of the steps into the basement. If we can manage to get it down there, id thee any reason we can't leave it in the box for a few days before we install it?0
(is there) typo. I'm assuming there's no perishable materials with a new boiler that need to be installed or connected within a day or two, right? Our maybe a bit moist, but other than that?
If you demo the old one yourself and haul it out in individual sections you will appreciate the weight of fully assembled item.0
Removing the old one first to see how we feel sounds like a good idea. We removed a brick-lined furnace a few years ago, and ended up rolling it over iron window-weights to move it across the back yard. The 4 of us had 3-4 hours of fun!
It was suggested we mark the old waterline on the wet return pipes before removing the old boiler-anything else we need to memorialize before we remove the old boiler?
Alterntaley, could we just tarp-up the new boiler form the pallet, and keep it in our secure fenced-in backyard for a few days and wait for the new installer to help us with moving it in? I think the seller will deliver it with a lift-gate to our doorway (or backyard).0 -
Covered with a water proof tarp should be fine. Keep it on the skid, up off the ground.
Maybe tarp-ing it up well for a few days if needed in the secure backyard, and waiting for the powered hand-truck & installer seems like a smoother way to go with less damage & injury risk.0
Yep, but you'll still want to take the cabinet panels off. As Hat said, otherwise they will be damaged.0
Any thoughts on how many hours the demo & removal of the old WMC EGH 75 might take if we have a sawzall or can get the blocks apart with standard rod removal? Any if things don't go very smoothly?0
The Weil McLain EG75 only comes as a knock down. So basically the block is assembled but all the jacketing and controls are in seperate boxes, the burner draw comes in a box fully assembled and only needs to be slid into the boiler and bolted in with 6 bolts and nuts, and the gas valve needs to be installed, they include the collector hood and refractory cement to seal it. The block does weigh over 700lbs, get alot help moving it, and use a good appliance truck, or better yet see if your local rental shop rents powered appliance trucks, this makes life easy.DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
Once you cut the draw rods with a sawzall get a big pry bar and split the sections, Weil McLains come appart easy since there are only rubber seals between the sections and not push nipples. The individual sections weigh about 100lbs each.cubicacres said:Any thoughts on how many hours the demo & removal of the old WMC EGH 75 might take if we have a sawzall or can get the blocks apart with standard rod removal? Any if things don't go very smoothly?
My slantfin tr50 came as knock-down units, so no worries about the panels. I kept mine on the original pallets and wrapped in plastic for months before my install with no ill effects. I don't see why it be a problem.Two-pipe Trane vaporvacuum system; 1466 edr
Twinned, staged Slantfin TR50s piped into 4" header with Riello G400 burners; 240K lead, 200K lag Btus. Controlled by Taco Relay and Honeywell RTH6580WF0
- 87.8K THE MAIN WALL
- 130 Chimneys & Flues
- 79 Pipe Deterioration
- 396 Solar
