Insulating Wet Return in One Pipe Steam System?
Jeff_H
Member Posts: 37
I have a one-pipe steam heat system. I understand the importance of insulating the mains, but should I be insulating all the pipes (such as the wet return)?
Frankly, I wouldn't. Why? Well, first place it shouldn't be that warm, so there isn't much gain. Second, you really don't want to trap moisture next to the outside of the pipe, which would corrode it.Br. Jamie, osb
Thank you! Interestingly enough, I had corrosion on those exact pipes and had them replaced. Would you insulate the Hartford Loop piping as well?0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
