Insulating Wet Return in One Pipe Steam System?
Jeff_H
Member Posts: 37
I have a one-pipe steam heat system. I understand the importance of insulating the mains, but should I be insulating all the pipes (such as the wet return)?
Frankly, I wouldn't. Why? Well, first place it shouldn't be that warm, so there isn't much gain. Second, you really don't want to trap moisture next to the outside of the pipe, which would corrode it.Br. Jamie, osb
Thank you! Interestingly enough, I had corrosion on those exact pipes and had them replaced. Would you insulate the Hartford Loop piping as well?0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 942 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
