contractor in Northern NJ for converting steam radiators
klagreca
klagreca Member Posts: 6
Hi folks,
I have 5 steam cast iron radiators in our lovely home that I need converted for hot water. Basically I need 1) air bleeders tapped, 2) old steam valves replaced with HW valves, and 3) the large nut sawed out for use as a return.
Can anyone recommend someone in the North Jersey who has experience with this? I don't know where to start. Thanks!
  • KC_Jones
    KC_Jones Member Posts: 5,916
    Do these radiators have connections across the top? If they don't they can't be converted. Only certain ones can be converted. Post a picture and we can tell you. Have you tried the find a contractor link?
    2014 Weil Mclain EG-40
  • klagreca
    Hi KC Jones, thanks for the reply.
    Yes, they're connected across the top and even have a bleeder plug (which needs to be tapped because it's probably welded closed at this point). They're in very good shape.
    The contractor link returns results for NYC and brooklyn. The closest NJ contractors are in central NJ. I called them and they won't service my area.
    Any leads would be appreciated. Thanks!
  • RobG
    RobG Member Posts: 1,844
    Try @JStar, Thatcher Plumbing and Heating. They are an excellent company and will do right by you.
  • klagreca
    Thanks Rob! Jstar was actually the first person I called, even before posting my first message. I'm sorry to report that as of August 2015, Thatcher is no longer in business. :/ Sorry to be the bearer of bad news.
  • RobG
    Sorry, I knew JStar was looking to retire but did not know he had already done so. Have you tried Langan's plumbing and heating? Rich and john are very knowledgeable with hot water heat.
    Zman
  • JohnNY
    JohnNY Member Posts: 3,346
    Gateway Plumbing & Heating has a shop in Orange.
    Consulting & Troubleshooting
    Heating in NYC or NJ.
    Classes
    RobG
  • dlebnikoff
    dlebnikoff Member Posts: 6
    My name is Don from Jay Ell Plumbing and Heating i just
    moved by business from NYC to Northern New Jersey. Where are
    New Jersey are you?
