Ecentric Bushing
steveo1
Member Posts: 8
Hello everyone
Where in the world can I find a 2" x 1/2" Ecentric bushing for a Steam radiator.
I've been able to find a coupling however my riser pipes want allow for any movement.
Use one of those bushings they use on oil tanks, 2-inch with two 1/2" tappings in it. Many times these come with brass fittings already installed, so take them out and use them for something else. Plug the remaining hole.
Edit- you can get these from R.E. Michel as catalog # 8K107.All Steamed Up, Inc.
Consulting2 -
I wish I had known about that part! I looked long and hard for eccentric bushings. I salvaged a few from some scrap radiators. I also found that you can use a short 2" nipple and an eccentric reducing coupling, which is available from Anvil. But, space limitations may make that not an option in some cases.Dave in Quad Cities, America
http://grandviewdavenport.com0 -
mcmaster.com0
Post a pic of where u need to use it0
I found a 2x1/2x1/2 oil tank bushing like Steamhead recommended.
Thank you all that posted.
Johnstone Supply had one along with RE Michel0 -
Great idea. We call them duplex tank bushings.0
I have had to go old school and make them. Forged plugs are available with a hex head. I then drill and tap the plug to suit what I need.Cost is what you spend , value is what you get.
cell # 413-841-6726
Zoro supply actually carries eccentric reducers.
http://www.zoro.com/anvil-cast-iron-eccentric-reducer-couplings/g/00121911/DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
Specializing in Steam Heating, Serving the residents of New Jersey
https://heatinghelp.com/find-a-contractor/detail/dl-mechanical-llc
https://m.facebook.com/DL-Mechanical-LLC-315309995326627/?ref=content_filter
I cannot force people to spend money, I can only suggest how to spend it wisely.......0 -
We are looking for bushings not couplings though.Cost is what you spend , value is what you get.
cell # 413-841-6726
Opps didn't see that.Charlie from wmass said:We are looking for bushings not couplings though.
No problem. We all do that at times. Me especially.Cost is what you spend , value is what you get.
cell # 413-841-6726
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 984 Plumbing
- 389 Solar
