Twittered steamer..,,,
kcopp
Member Posts: 4,555
I suppose no one on that site bothered to check the manufacturer's piping diagram...................All Steamed Up, Inc.
Consulting1 -
Bullheaded tees - the latest innovation in steam heating inefficiency.1890 near-vapor one pipe steam system | Operating pressure: 0.25 oz | 607 sf EDR
Midco LNB-250 Modulating Gas Burner | EcoSteam ES-50 modulating controls | 70 to 300 MBH |
3009 sf | 3 floors | 14 radiators | Utica SFE boiler | 4 mains, 135 ft | Gorton & B&J Big Mouth vents1 -
"New boilers don't need to be high efficiency" the caption they posted with the picture. At least they got that part right. lmao1
Ugh. Just...ugh.0
Hey: Maybe it works? When the steam in the 2" pipe hits the tee, it'll slow down when the hallway opens up to 3", dropping its water wad into the neutralizer.
But I know squat about steam.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
I wonder if in a decade or so, if those press fittings will leak??? time will tell.gwgillplumbingandheating.com
I have immedaite regrets about the vertical header idea.Hatterasguy said:There's your vertical header Joe.............ought to ask them how it works for them...............
sad that the installer thought it was good enough to tweet, and sad that whoever runs supplyhouse's twitter feed thought it was good enough to retweet.
and even worse... Weil-McClain's response to the tweet:
"What a great photo! Can you send us the original image and any other ones from your job sites? marketing@weil-mclain.com"
Must be the same W-M guy who said there was nothing wrong with using a copper header.....
The boiler manual shows threaded pipe and specifies swing joints- go here:
http://www.weil-mclain.com/en/assets/pdf/sgo-boiler-manual_1014.pdfAll Steamed Up, Inc.
Consulting2 -
Are those fittings even certified for steam? That's the first time I've seen them used.
Do you think that header (if you want to call it that) will be holding water?0 -
Well,
That's the last time I buy a WM product. Hopefully my EG series will last another 20 years so I'll need to see if their people have their heads removed by then or not I guess.
Unbelievable.
Thanks @kcopp I'm leaving for the dentist soon and am expecting some pain. I didn't need some before hand.
Once again, I should be forced to hire guys like this because I'm not licensed? Yeah right.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Looks like Viega states that they are rated for up to low pressure steam up to 15psi. I'm sure that "header" has plenty of water in it.RobG said:Are those fittings even certified for steam? That's the first time I've seen them used.
Looks like someone is trying to save face....0
Hmmm that looks familiar.2
wonder if the installer is going to regret not being able to unscrew those fittingsgwgillplumbingandheating.com
I have a feeling he may not go back there.....0
He will think he did a great job no matter what is said. He got recognition from a supply house and the manufacturer. Sad really sad.0
You can't fix stupid!Hatterasguy said:
.............Race to the Bottom...........JStar said:And WM will probably feature him in a newsletter where other contractors will see what an "great" installation looks like.
Consulting0 -
I think if the bar keeps getting lowered it's going to end up in China!0
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 971 Plumbing
- 386 Solar
- 17 Recall Announcements
