pex distribution on potable water.
Ok so what is the real answer.Since plumbers in my area have been using pex they refuse to use a homerun system.They run 3/4 and 1/2 inch pex.When I look at the fittings the ID of a 3/4 pex fitting equals the ID of 1/2 inch pex.Am I wrong but wont this cause tremendous restrictions on water volume to fixtures.I rather use copper but price wise its getting harder so I use a homerun with pex but they tell me I am going overboard.How do you guys install it?.
Thanks.
Thanks.
Uponor Logic. Just wish they would offer fittings for 3/8" PEX.0
It's a branch system, but they have multi-port EP fittings that make it easy to pipe a bath or kitchen using a lot less parts.0
Thanks Hatt,thats what I am running into long runs of pex feeding showers with body sprays etc.Thats my main concern.
When are we meeting up again?0 -
No recirculation shown @ Uponor Logic0
Around these parts, we don't allow pex tee and branch distribution method. That is specifically with the insert crimp fittings. The uponor method is fine. Larger bore in the fittings, less pressure drop.
Download the pex install manual and check out the pressure drop of the insert fittings. It's huge. About 5 or 6 times the loss of copper.2 -
Thanks Harvey0
Home run with manifold, but like you I don't like it....worse yet CPVC...Don't even like pro press....Maybe old school, but I guess if I were still in competitive business I would have to entertain the new yuppie stuff.....0
- 87K THE MAIN WALL
- 113 Chimneys & Flues
- 106 Geothermal
- 981 Plumbing
- 388 Solar
