How Far?
j a_2
Member Posts: 1,801
Was just wondering, how far below the mason dixen are/were steam heating systems used? We have an incredible amount here on the New England area.. Many of them never touched, since installed. A steam guys love..
I have seen quite a few in my travels to North Carolina.My relatives there have a tough time getting someone competent to work on theirs. I think they finally found a New York transplant that knows steam.
The Biltmore estate outside of Asheville has a fantastic steam system from 1890. Not to mention AC and DC power, an elevator, intercom and walk in coolers. You can get a "butlers tour" of many of the inner workings for an extra fee. It is really easy to get "lost" and fall off the back of the group (into boiler rooms) if you are careful.
Albert Einstein1 -
We know of two systems in Huntsville, Alabama- one Vacuum and one Vapor. These threads are from several Wall generations ago, so some of the posts are scrambled:
http://forum.heatinghelp.com/discussion/104173/need-help-understanding-dunham-system
http://forum.heatinghelp.com/discussion/95109/cousin-margaret-and-warren-websterAll Steamed Up, Inc.
Consulting0 -
Ft Meyers, Florida has the Edison museum with steam radiators in it, however I do not know if it is functional. Not far away, Boca Grande has the Gasparilla Inn with a working one pipe system.
two pipe would have been better.--NBC0 -
Old Thatcher, Beckett AF and a Watts low water cutoff0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
