Why would heat come from baseboard unit when heat is off?
debo1323
Member Posts: 1
in Oil Heating
We have oil hot water heat. The heat is OFF, thermostat off, but one baseboard unit is still throwing heat - why would this be?
Does the boiler also make your domestic hot-water? It may be running past its control parameters and sending heat into the system.0
Or, you may have a flow check that's not shutting all the way off.JStar said:Does the boiler also make your domestic hot-water? It may be running past its control parameters and sending heat into the system.
Bob Boan
You can choose to do what you want, but you cannot choose the consequences.1 -
post a pic.0
