Why would heat come from baseboard unit when heat is off?
We have oil hot water heat. The heat is OFF, thermostat off, but one baseboard unit is still throwing heat - why would this be?
  • JStar
    JStar Posts: 2,752
    edited May 2015
    Does the boiler also make your domestic hot-water? It may be running past its control parameters and sending heat into the system.
  • Ironman
    Ironman Posts: 7,950
    Or, you may have a flow check that's not shutting all the way off.
    Bob Boan
    Patchogue Phil_2
  • j a_2
    j a_2 Posts: 1,804
    post a pic.
