Split & Reno
Hilly
Member Posts: 427
So I am looking at a new house. And hot water would be a hard retrofit and might not be worth the current investment restrictions. Can one recommend a good setup for a 'Backsplit' or 'Multispilt' style home. I am going there tomorrow for full measurements so I can get started on the Heatloss so that will be done. It's a home I am looking to purchase for myself (wife and family included). The levels are all aprox 550 ft^2 each. L1)Wide open 6' below grade basement - will be a workout are and laundry and maybe half bathroom
L2) front and back entry, half bath, two rooms (office/tv probably uses)
L3) open concept kitchen, dining and living room.
L4) full bath and 3 bedrooms.
In our current home we have lg cool art mirror finish minisplit system and we are comfortable with the look of splits if it's the most practical solution. Or would a hybird system be best, ducted split for bedrooms, wall or ceiling cassette for open living area. Honestly I'm open to the most practical option. Goal being that electrical costs lower a bit from existing baseboard system and added AC for a wife with Hypothyroid so she drips sweat in the summer even in our climate where warm is a day to get excited for. hahaha
In short looking for brand recommendations and distribution setup for this stlye home. There will be enough of a reno to do most anything.
Ductless split, Mitsubishi seems to be the go to brand.0
I do like Mitsubishi," City Multi". At last check they allowed something like 1-12K AND 2- 9k ON 1 CONDENSER. I'm sure this has probably been improved, but check it out. Although I am not a fan of mini-split systems I guess the have their place in the world. I would most like to see Hi Velocity equipment by Unico and the like. From a service point of view, I find it increasingly difficult to work on Mini's made for people with uniform 1/2" diameter fingers.............:-) Really.
MPT...0 -
What's the heat loss and outdoor design temp?
Fujitsu, Daikin, and Mitsubishi all have (and support) quality options at this point.0 -
Not sure of the her loss yet, it's a property in hoping to purchase. Design temp is 6F0
Every residential multi-split I've sized to date (at our 10-14°F winter design) required a larger outdoor unit than the heat loss would have dictated just to accommodate enough indoor heads to meet the client requirements.
Info from currently available Fujitsu models: 2 heads allowed on an 18k, 3 heads on a 24k, and 4 heads on a 36k. The 48k will handle 4-8 heads, but beware: Once you go over 4 heads, splitter boxes are required -- and those add up quickly.0 -
It is mainly for sup heat and air conditioning for my wife. The house is a side split so I'm hoping least invasive options.0
I know almost nothing about high volecity systems, think they'd make a good option?0
Spacepak and its ilk is fairly non-intrusive and practically invisible once installed.Two-pipe Trane vaporvacuum system; 1466 edr
honestly in my current home we have the mirror finish from LG and the look is actually quite pleasing for what you get.0
I'll have to draw up a floor plan and post a picture. Maybe I'll setup a poll as to what will give me the best. Main issue is that I have a budget below 20k for this project. So I had to avoid anything solar or geo but maybe radiants walls could be an option. I'll be back with some details.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
