Code??? Oil Boiler, Hot Water heater & Oil tank in garage
bausencm
Member Posts: 2
in Oil Heating
Can someone please adivise as to what the code is for placement of oil burner, hot water heater and oil tank in an attached garage in Port Jefferson Station, Brookhaven township??
Is there no local AHJ you can ask? Town building inspector?0
I *think* we follow nys code. You can call town hall to be sure.
http://publicecodes.cyberregs.com/st/ny/st/b1100v10/index.htm0 -
Not sure about New Jersey but what Robert said sounds right0
What Robert said, and best to add a vapor barrier, tank no closer that 5 feet from the unit, lally columns where impact might be a possibility, outside air intake, no open returns in garage if warm air to name a few. There are different codes for different areas. Check locally0
Thank you. I am trying to get confirmation from the building dept in the town of brookhaven but it is not as easy as it sounds to reach someone by phone.0
What do you want for the trifling amount of property taxes?
- 120 Geothermal
