Code??? Oil Boiler, Hot Water heater & Oil tank in garage
bausencm
bausencm Member Posts: 2
Can someone please adivise as to what the code is for placement of oil burner, hot water heater and oil tank in an attached garage in Port Jefferson Station, Brookhaven township??
  • bmwpowere36m3
    bmwpowere36m3 Member Posts: 512
    Is there no local AHJ you can ask? Town building inspector?
  • Robert O'Brien
    Robert O'Brien Member Posts: 3,584
    All ignition sources must be 18" above a garage floor. Oil tank will require stanchions. I'm in Mt Sinai
    icesailorbausencmZman
  • Patchogue Phil_2
    Patchogue Phil_2 Member Posts: 316
    I *think* we follow nys code. You can call town hall to be sure.
    http://publicecodes.cyberregs.com/st/ny/st/b1100v10/index.htm
    EBEBRATT-Ed Member Posts: 19,310
    Not sure about New Jersey but what Robert said sounds right
  • billtwocase
    billtwocase Member Posts: 2,384
    What Robert said, and best to add a vapor barrier, tank no closer that 5 feet from the unit, lally columns where impact might be a possibility, outside air intake, no open returns in garage if warm air to name a few. There are different codes for different areas. Check locally
  • bausencm
    Thank you. I am trying to get confirmation from the building dept in the town of brookhaven but it is not as easy as it sounds to reach someone by phone.
  • Robert O'Brien
    What do you want for the trifling amount of property taxes? :)
