rattling radiator
I have one radiator that sounds like it has marbles in it, mainly when system starts cycling from cold. Sounds like the valve disc might be loose. Is that possible?
    Jamie Hall Member Posts: 26,839
    Hot water or steam? Either way, it could a loose disc. If hot water, could also be air.
  • Fred
    Fred Member Posts: 8,542
    It certainly is possible. The nut that holds the disc on sometimes comes loose and sometimes even just break off.you may have to disconnect the radiator or remove the bonnet on the top of the valve to check and fix it. Maybe should wait for a warm day.
  • scotdog
    scotdog Member Posts: 2
    Steam heat radiator....
    jbmoff
    Check that valve. The disc could well be loose -- or fallen off completely! Could also just be partly closed.
  • GoodOldSteamHeat
    GoodOldSteamHeat Member Posts: 1
    It is possible for your steam valve to rattle even if it still working properly; skimming and cleaning the boiler did the trick for me. Here is the list of everything we tried. ...
