three way radiator valve
teresad
teresad Member Posts: 4
how does this valve work? need to replace frozen and broken radiator anything to be concerned with?
  • teresad
    looks like picture didnt post. can try again later its an old three way radaitor valve only one inlet to radiator
  • SWEI
    SWEI Member Posts: 7,348
    Does it look like this?
  • vaporvac
    vaporvac Member Posts: 1,520
    Completely unrelated to the valve, I find it fascinating that the link is comparing HW to steam, with steam as the obviously superior thing. What happened?
  • teresad
    Thats it! Do radiators have the same heating capacity? the one we have seems large for a 14' sq bedroom
  • Abracadabra
    I'm not sure, but the only way I could see that working is if there was a long lance/probe which connected the return to the far end of the radiator.
  • icesailor
    icesailor Member Posts: 7,260
    That's kind of what's in there and how they work. Some things work better, Probably why you don't see many of them.
