three way radiator valve
teresad
Member Posts: 4
how does this valve work? need to replace frozen and broken radiator anything to be concerned with?
looks like picture didnt post. can try again later its an old three way radaitor valve only one inlet to radiator0
Completely unrelated to the valve, I find it fascinating that the link is comparing HW to steam, with steam as the obviously superior thing. What happened?Two-pipe Trane vaporvacuum system; 1466 edr
Thats it! Do radiators have the same heating capacity? the one we have seems large for a 14' sq bedroom0
I'm not sure, but the only way I could see that working is if there was a long lance/probe which connected the return to the far end of the radiator.0
That's kind of what's in there and how they work. Some things work better, Probably why you don't see many of them.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
