Heat Pipe in Apt building forming rust
If management is bad perhaps you should explain to them about the lawsuit from someone getting burned when the pipe lets loose. Usually the threat of litigation gets people into action when nothing else will. If you are seeing external corrosion like that 9 out of 10 times that means a leak has started and won't get better. Is this steam or hot water heat?1
This is a steam system I believe. An old (building from around 1947) one and the pipe does get very hot. I am in Astoria, Queens New York. When I alert management they don't say anything or even come to look at the issue. I have even sent them pictures of this issue on a week by week basis. It's not a low rent apartment @ 2k a month for rent. Who should one contact if management is not getting back. Thanks so much for your help!0
In n.y. Don't they hace 311 number for that0
i'm guessing the radiator upstairs is leaking, probably from the valve.0
- 50 Industry Classes
