A solution to those nagging 1,000 foot loops of 1/2" PEX...
"Well ya wonder why I always dress in black..."Steve Minnich0
What's the head pressure?0
Chris, I honestly don't know, and wouldn't advise that anyone attempt to install a pump of this size in a residential setting. It was just the biggest friggin' pump I'd ever seen at a trade show. I tried to get Siggy to stand in front of it so I could take his picture, but he thought better... This was a 480 V, 3 phase pump typically used for cooling tower applications.
ME0 -
We videotaped at Armstrong and I also enjoyed standing near that big boy (the pump, not Mark).Retired and loving it.0
Dead heading would be quite spectacular.0
I saw a guy taking a nap inside that volute
Or maybe it was an elf. Bob "hot rod" Rohr
Kirk Vigil of Grundfos said they make one that you can actually stand fully upright in the flanges. Now THAT'S a pump...
ME0 -
Ice, I was on a gardening site yesterday and a fellow who listed himself as the ultimate diy'er is going to put radiant in his 1200 sq ft home with a tankless. He felt that in spite of what he had read on some sites that he could do it with up to 1000' loops. It's like Monty Python where the knight goes into the cave and the rabbits kill the knights. "Run away, Run away!"0
The outcome will be acceptable because he did it himself, and doesnt know what is acceptable. OR you will never hear the outcome. Well you might because he will end up here looking for that 4 way reversing valve set up.Jack said:Ice, I was on a gardening site yesterday and a fellow who listed himself as the ultimate diy'er is going to put radiant in his 1200 sq ft home with a tankless. He felt that in spite of what he had read on some sites that he could do it with up to 1000' loops. It's like Monty Python where the knight goes into the cave and the rabbits kill the knights. "Run away, Run away!"
Might be a money maker. Explicit instructions to throw away before you begin would be required. Use toilet paper to maximize profits.SWEI said:
I'm wondering if I should put together a little package for that and advertise it online...Gordy said:he will end up here looking for that 4 way reversing valve set up.
I've built a few of those reverses, the last with a tekmar 4 way and heavy duty Belimo actuator. Remember they also need a high head circ included. A reverser on a 1000 foot loop with a 15-58 size circ would not do much.
With a 26-99 size circ and a reverser you can get some fairly good results.
A lot depends on the loop layout as with reversers you warm both ends of the loop, but the middle 1/3rd still sees low supply temperatures, you just sneak up on the load from two different directionsBob "hot rod" Rohr
Living the hydronic dream1 -
Fear not. The DIY will use a iron body 007 because it is cheap.
And someone on the Internets told him that the 007 "Might work for you. I've never seen it ever work for anyone else, but it might work for you". Not understanding the context of the encouragement, he went right ahead.
It reminds me of something my mother used to tell me when I was really little. About the person who wanted to do things.
There once was a thing,
That couldn't be done.
They said no one could do it.
So he tackled the thing,
That couldn't be done,
And by God, he couldn't do it.0 -
Seven hundred of them in parallel across an airport hanger slab?archibald tuttle said:but 'seriously', that pump is a real help for those of us who prefer 3/8" loops.
with that pump maybe i could do series . . . not0
null
Ouch!0 -
null
Good luck to him he could be on animal planet wrestling anacondas on the Amazon.0 -
Nice!
No longer will there be a problem with which circ wins the battle. A wall of them and you are "Golden" .
lol... It is as Mark said , "no need for a boiler" . No more short cycling in shoulder seasons , lash it up primary secondary to a LLH . Shut down the boilers and move wire to water.
Sweet!0
- 50 Industry Classes
