Buderus Mix Stations
Warmfoot2
Member Posts: 3
I installed a couple of Buderus Mix Stations about ten years ago. The 3-Way Mix Valves have seized. Buderus no longer supports the mix stations. Would anyone have any ideas on where to get replacements? I have a hard time believing that Buderus manufactured these units themselves.
Ouch, I think you want a rebuild kit before you open the hood. I would think Buderus could look up the supplier of that valve?
Here is a shot of what is inside this older Esbe brand.Bob "hot rod" Rohr
I think those stations used ESBE valves, so you might be able to get parts or replacements from them.0
FYI - Found 3-way valve rebuild kits from Buderus - They order them from Watts. 6-week lead time. The motors have to be purchased from Buderus as well. Very expensive - Found one on Ebay for 1/4 the cost. will have to order the 2nd one from Buderus.
Ernie0 -
I'll update with pictures when I rebuild it as well...
