Buderus Mix Stations
I installed a couple of Buderus Mix Stations about ten years ago. The 3-Way Mix Valves have seized. Buderus no longer supports the mix stations. Would anyone have any ideas on where to get replacements? I have a hard time believing that Buderus manufactured these units themselves.
    hot_rod Member Posts: 27,830
    Ouch, I think you want a rebuild kit before you open the hood. I would think Buderus could look up the supplier of that valve?
    Here is a shot of what is inside this older Esbe brand.
  • JeffM
    JeffM Member Posts: 185
    I think those stations used ESBE valves, so you might be able to get parts or replacements from them.
  • Warmfoot2
    Warmfoot2 Member Posts: 3
    FYI - Found 3-way valve rebuild kits from Buderus - They order them from Watts. 6-week lead time. The motors have to be purchased from Buderus as well. Very expensive - Found one on Ebay for 1/4 the cost. will have to order the 2nd one from Buderus.
    Ernie
  • Warmfoot2
    I'll update with pictures when I rebuild it as well...
