new to this, need help with hissing, steaming vent
nycnewbie
Member Posts: 3
Hi All
I need help with a hissing, steaming vent on top of a pipe in my kitchen. When the boiler starts up, it clangs for a short bit and then it hisses and steams for a long time before it quiets down. The pipe is 5" in circumference and the vent that is currently on there is a Hoffman No. 41 (at least that's what's stamped on it). Will a different vent fix the hissing? I'm on the sixth (top) floor of a building from the 20s.
I'm new to the area and this is my first experience living in a steam building. I found out the super started a two week vacation when I moved in and complained about the sputtering and clanging radiators. I spent the last few days reading online and swapped out vents on the radiators that were clanging and sputtering, they're quiet now. I'm a bit strapped for cash right now and anyway I'd like to know more about steam heat as I'm going to be living with it now. Thanks in advance for any help!
Ok. Here's a photo a further out. The layout of the kitchen forces the weird angle....0
I think that is a vent for the riser in the building. Probably needs a much larger vent, like a Gorton #2 Or even a couple of them but that would require the tapping to be opened up to 1/2". I wonder what the Boiler pressure is running at? Lowering the pressure will help also and save the Landlord fuel money.1
Almost certainly a vent for the riser since you are on the top floor. I think Fred is onto something. The pressure is a possibility, but if you have been able to tame the other rads it's hard to say. Too high of system pressure can kill vents so time will tell if your other vents hold up or not. It would probably be good to know system pressure, if they know and if they will even tell you.0
OK, I'll try to find the system pressure... Thanks!0
You could actually install a gauge on that port where the vent is.0
I assume your are a tenant in this building. If so, you should never make changes in venting especially on the top floor. The steam system is the responsibility of the landlord. Even in a Coop which i live in, only the board can approve such changes. I am in charge of the heating in my Coop and I am a board member and officer and I have to get permission or give notification before I make changes.
- 87.1K THE MAIN WALL
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
