Possible to eliminate ugly indoor ventilation bulkhead and replace it with something new?
Renothecondo
Member Posts: 3
My condo has gas heat and built in the 1970's. There is an ugly ventilation bulkhead that runs down the ceiling of the living/dining area. Is it possible to eliminate the bulkhead and replace it with a newer ventilation that is built into the ceiling?
What does this "Bulkhead" look like?0
It's like a hanging rectangular box that runs along the ceiling the length of the room...and abutts the wall. I'll try to attach a picture.0
Ok, well thanks for your reply. That's what I was told by someone else but thought I'd get another opinion. I really appreciate it. :-)0
Your "bulkhead" is not really providing ventilation as no air is being vented.. It is heating your house by using forced (scorched) air heat.
I agree that you most likely cannot remove the duct and keep the forced air. If you are doing extensive renovating it might be worth considering a hot water system. You can move a similar amount of energy using (2)-3/4" pipes that could drilled through the joists. You would also eliminate the dusty nasty air blowing around."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0
