Hot water rad
Jim Pompetti
Member Posts: 552
how do I run a hot water baseboard , off of a steam boiler, when baseboard is 9 foot higher that boiler
shouldn't be a problem. Just make sure there are no vents in the piping and that the inlet and outlet are below the water line.0
You need a Bell & Gosett series 100 all bronze pump, two Bell & Gosett flo controls a by pass loop three ball valves and a fresh water supply to bleed the loop, a honeywell pump controler, and a Honeywell Aquastat to control the burner.DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
Specializing in Steam Heating, Serving the residents of New Jersey
https://heatinghelp.com/find-a-contractor/detail/dl-mechanical-llc
https://m.facebook.com/DL-Mechanical-LLC-315309995326627/?ref=content_filter
I cannot force people to spend money, I can only suggest how to spend it wisely.......0 -
Do you have a drawing0
- 85.7K THE MAIN WALL
- 50 Biomass
- 74 Chimneys & Flues
- 93 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 854 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.6K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 87 Job Opportunities
- 15 Recall Announcements
