Going commando!
You could also use soft copper tubing to connect the gauge as some vibration may simple be from the long iron pipe. Flared fittings and a couple feet of tubing in a nice vertical spiral and mount the gauge to something solid.Cost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating1 -
I think I'm going to order an adjustable 1/2" snubber from Dwyer.
They do have an 1/8" fixed one as well, but the 1/2" could protect everything on the line.
Charlie, I am considering remote mounting the gauge as well.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Yup!KC_Jones said:
Already have the wife's approval, I just need to make up my mind.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
I have seen that once. I looked a a job near Hartford CT and the priest had a gauge mounted in the living room of the rectory on a riser to the second floor so they could keep an eye on the steam pressure.Cost is what you spend , value is what you get.
cell # 413-841-6726
Well,Charlie from wmass said:I have seen that once. I looked a a job near Hartford CT and the priest had a gauge mounted in the living room of the rectory on a riser to the second floor so they could keep an eye on the steam pressure.
That stinks. I was hoping to be the first.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
I friend of mine went to someone's house recently and they had an original steam gauge installed on a riser in the living room. It was a useless 0-30 gauge, but it was there. As an added bonus it was actually originally made by a company in the town we live that has long since gone out of business. Sorry Chris you aren't the first...lol1
Isn't that always the way?KC_Jones said:I friend of mine went to someone's house recently and they had an original steam gauge installed on a riser in the living room. It was a useless 0-30 gauge, but it was there. As an added bonus it was actually originally made by a company in the town we live that has long since gone out of business. Sorry Chris you aren't the first...lol
Kinda hard when there's already been billions and billions of people around.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
If that were true we would never have anything new. I will go out on a limb and suggest you are the first to ever put a Magnehelic on a steam boiler!0
Perhaps,KC_Jones said:If that were true we would never have anything new. I will go out on a limb and suggest you are the first to ever put a Magnehelic on a steam boiler!
But I think @MarkS already had a Magnesense which is the digital version. I believe it uses a hall effect sensor.
Yeah, that would work.MarkS said:And now I have a 2nd Magnesense on a main. This week I've been controlling firing rate of off mains pressure. Would you believe 0.28" WC?
Chris, isn't your ultimate objective to have your living room look like the control room in "The China Syndrome" (without the nuclear meltdown, of course)?
@SWEI, when ChrisJ throttles the valve, isn't he in effect creating the "wide spot in the line" on the gauge side?
This would be cool too.
Let's not forget @Dave in QCA. He also has an original gauge in the dining room of the Best mansion. I covet that, but I would be happy with a remote wi-fi reading!Two-pipe Trane vaporvacuum system; 1466 edr
I am pretty sure my grandfather has one of those round gauges from that old picture. Can't remember what it measures though....haven't seen it in years! I have this one that actually has a frame and a thick glass top (not shown) and he used to have as a coffee table....still working on wife to bring it out of the attic. And yes that is my hand in the one picture for scale...it's big!
Except at 150 PSI it would just sit there and do nothing. hmmm wonder what it would take to retrofit a low pressure mechanism in it? Never mind I don't think I could bring myself to hack it up.0
you could use a multiply to use it. one close cylinder of a given diameter pressing a ram into a smaller cylinder to make the pressure multiply to move the scale.
cell # 413-841-6726
That would have to be one heck of a multiply! And now my mind is working on how to do that.0
two air pistons of different displacements.Cost is what you spend , value is what you get.
cell # 413-841-6726
a 4" to a 1" bore would be 16 to 1Cost is what you spend , value is what you get.
cell # 413-841-6726
I suppose you could look at it that way, but now we've added a venturi to the system - perhaps making it even more like an organ pipe. I'm sure the snubber will work, but it would still be interesting to see if a really simple, low tech solution would damp the response appropriately.MarkS said:when ChrisJ throttles the valve, isn't he in effect creating the "wide spot in the line" on the gauge side?
How does this compare to it "fully dressed"?Two-pipe Trane vaporvacuum system; 1466 edr
Can you run your Magnehelic wide open or are you throttling the valve?MarkS said:The EcoSteam development system goes commando!
Replaced the pigtail on the low pressure instrument stack with an elbow and raised it about a foot above the boiler. Had to change the tuning of the pressure control PID loop because the MagneSense digital pressure transmitter is much more responsive than it was on the pigtail. The bottom nipple barely sees any heat from the steam. The system does pull a very slight vacuum (< 0.1" WC) for a few minutes after the boiler shuts down.
Finally got my hands on a snubber for the setup.
0.015" hole sure looks a lot smaller than I expected. This is a 1/4" NPT snubber.
The other options from Mcmaster are 0.008 and 0.004.
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
