Split a single pipe radiator to two rooms
jgem
Member Posts: 3
I want to split a bedroom into two smaller bedrooms. Problem is there is a single pipe steam radiator. I'm wondering If it's possible to put two smaller radiators on the same single pipe? I'm thinking it can't be done but I'm no expert. I've attached two pictures to explain what I'd like to do. I think I can run a pex line and tap into the boiler but I'd rather not do that. Thanks for any insight!
Technically, it will work if the new radiators equal the same capacity as the old one. However, we always see this setup cause some type of problem. If it's your only option, go for it. If you can, though, I'd rather install a dedicated supply line to each radiator.
And never use PEX for steam. It must be black steel pipe and fittings.1 -
I'm not sure I've ever seen a 2 way steam valve. You will have to find a way to tie into the riser and branch off of that and put a steam valve on each radiator and make sure the new piping and radiator have enough pitch to drain back to that riser.0
I like the steam heat but it tends to be limiting in an old house like mine. Thank you for the replies. I do think if I'm going to stick with the steam it's my only option. Both rooms will be small so an electric baseboard may be the way to go.0
I have another thought for you, but it would be good for a pro to chime in with their thoughts on this. What about using the existing radiator between the 2 rooms? Do a minor re-pipe in the room and put the radiator in the wall between the 2 rooms. you could build an opening between the 2 room put the rad in that and then put a radiator cover on either side. It would cut down on the output some, but typically these are over sized for the space anyway. Again a pros opinion on this is welcome. This is an idea I thought about a while ago for a similar situation I am trying to work on for my own house. It also depends on your dividing wall being relatively close to where your pipe is now.0
I like that idea too. Thanks! my whole objective here is to give the kids their own rooms, which will be really small all said and done. Putting the rad in the wall would save a good amount of space. Definitely an option.0
Shouldn't be a problem either way. If you use two small radiators, just make sure that the combined EDR isn't much greater than the one that's there now. Then make sure that all the piping is pitched properly and you should be good to go.
The in wall idea is interesting. Depends a lot on how much privacy your kids want!Br. Jamie, osb
Definitely a minor drawback, but if they add a rad cover of some sort on either side it will help. The sound will still travel, but hey they are kids they may just find something cool about it. What's funny is the reason I thought about it was I am planning on adding rooms in the attic of my house and was thinking of doing this in that situation because I have an extra rad that someone else removed sitting in my basement. One rad 2 rooms...the mother of invention.Jamie Hall said:
The in wall idea is interesting. Depends a lot on how much privacy your kids want!0
- 116 Geothermal
- 169 Indoor-Air Quality
