Strange noise
zoominoff
Member Posts: 7
Hi,
I am hearing a very strange noise from my boiler, and was hoping to get some thoughts before talking to a heating specialist, just so I can sound reasonably knowledgeable. Here is a video:
https://www.dropbox.com/s/0r4pjkr9zmu4pks/Boiler-Noise.MOV?dl=0
The system is a Teledyne Laars Mini Term II. I think it's kind of a unique system- there is no separate boiler tank. The system handles both heat (forced hot water) and domestic. I think there is a small tank inside.
Thanks in advance for any thoughts.
-Zak
-Zak
The ignitor makes a sound similar to that.I think your noise is more metallic than that.
That sounds like a relay that has either gone bad or is getting fluttering power.
It's pretty loud so it should be easy to find."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
Is the boiler on when you hear the noise? I'm guessing maybe the solenoid on the gas valve?0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
