Replacing a Steam Radiator with another Steam Radiator
Hello - I have a steam radiator that recently started to leak at the bottom (rusted out). I have a different steam radiator that I would like to replace it with but has a slightly different configuration. Based on the dimensions below - would it be OK if I swap out the two radiators or would it cause any issues. Any tips would be greatly appreciated.
Current Radiator:
38" tall, 2 columns deep, 8 sections wide
Potential Replacement Radiator:
32" tall, 6 columns deep, 8 sections wide
This is a single pipe steam system.
Thank you
  • Snowmelt
    Snowmelt Member Posts: 1,457
    If it fits in place, piping you would just extend, also as long as the btu's match the radiaters you should be ok.
  • steamheatnewb
    steamheatnewb Member Posts: 29
    Actually piping height also seems different... the potential replacement radiator would require the pipe to be about 1.5-2" off the ground while the current one is a little more than 3"... so that is another problem I would need ideas on how to solve?
    Jamie Hall Member Posts: 26,807
    The size doesn't strike me as a problem -- although as suggested you might want a slower vent.
    The height could be. However,since you will need to use the replacement radiator's valve anyway -- or go to the trouble of taking the spud out of the existing radiator (the union between the valve and the spud has to match!) is there any access to put a shorter vertical pipe in to bring the valve to the new height? That's the best solution. The alternative is to raise the new radiator on blocks or something to fit.
  • wmtandson
    wmtandson Member Posts: 62
    yes just do it!
  • steamheatnewb
    Out of curiosity - how do you measure the EDR? I thought the EDR of the current one would be 28?
