Replacing a Steam Radiator with another Steam Radiator
steamheatnewb
Member Posts: 29
Hello - I have a steam radiator that recently started to leak at the bottom (rusted out). I have a different steam radiator that I would like to replace it with but has a slightly different configuration. Based on the dimensions below - would it be OK if I swap out the two radiators or would it cause any issues. Any tips would be greatly appreciated.
Current Radiator:
38" tall, 2 columns deep, 8 sections wide
Potential Replacement Radiator:
32" tall, 6 columns deep, 8 sections wide
This is a single pipe steam system.
Thank you
Current Radiator:
Thank you
If it fits in place, piping you would just extend, also as long as the btu's match the radiaters you should be ok.0
Actually piping height also seems different... the potential replacement radiator would require the pipe to be about 1.5-2" off the ground while the current one is a little more than 3"... so that is another problem I would need ideas on how to solve?0
The size doesn't strike me as a problem -- although as suggested you might want a slower vent.
The height could be. However,since you will need to use the replacement radiator's valve anyway -- or go to the trouble of taking the spud out of the existing radiator (the union between the valve and the spud has to match!) is there any access to put a shorter vertical pipe in to bring the valve to the new height? That's the best solution. The alternative is to raise the new radiator on blocks or something to fit.Br. Jamie, osb
yes just do it!0
Out of curiosity - how do you measure the EDR? I thought the EDR of the current one would be 28?0
- 119 Geothermal
- 394 Solar
- 15.9K Strictly Steam
- 50 Industry Classes
