Furnace in nee wall crawl space attic
rrwitherspoon
Member Posts: 104
I have a hot air furnace in knee wall crawl space behind bathroom. It is hanging from rafters. It provides hot air to attic and 2nd floor. The second floor has redundancy because it also has steam heat radiators. This furnace is not in conditioned living space and it is very old unit. There is also AC. I think this is very ineffiecient trying to heat house from unit almost outside and I am a little concerned about it age and carbon monoxide poisoning. The ductwork is very poorly
insulate. That round stuff with all the friction to air flow.
Are there other options to heat attic. Could we install a small boiler up there with some baseboard hydronic heating.
What unit would you recc? We are reinsulating because the insulation was done incorrectly in knee wall ares the bathroom floor tile was new but it is freezing.
good idea0
If you just want heat, those are an excellent choice. And they are out of the unconditioned space, in the room you want to heat.
If you need cooling/AC, put in a Mini-Split.0
