My first time using this pipe...already a big fan.
Steve Minnich
Member Posts: 2,868
I've added another type of pipe to my arsenal.
The two yellow pipes are oxygen barrier Pex tubing encased in an insulated corrugated pipe.
Ideal for running boiler or radiant pipe from one building to another or remote manifolds in snowmelt applications.
The black cap is a heat shrink cap. It starts out at 9" and after carefully putting a torch to it for about 10 minutes, it shrinks to the 6" OD the blue pipe. Seals everything water tight.
Every item you see there is pricey but absolutely the way to go in the above-mentioned applications.
Steve Minnich
What brand/type of pipe is it?Bob Boan
The brand is MicroFlex and I believe is they are connected to Watts in some way. It's Pex A with X-linked oxygen barrier. Those are 2 - 1 1/2" pipes plus the outer insulation and sleeve...definitely a 2 man job working that into place. The brass fittings you see were very easy to work with and seem to have been well thought out. My biggest surprise was seeing that 9" heat shrink cap morph into a 6" water tight cap. It took about 10-15 minutes per cap, less than 5 minutes per fitting.Steve Minnich0
If you do one again, make a 3 sided box (like a wooden miter box) the same sixe as the outside blue pipe out of 2" x 6" or 8" about 6' or longer, and put the pipe assembly in it for a few days or more. Use some shingles to pry apart the PE fittings and fittings. Put some high intensity work lights shining down on the assembly. It will warm up the pipe and make it take a true direction. Take it away and connect. It will want to take its old path. The only problem with that stuff is how hard it is to work with.
Those connecting adapters are standard A.Y. McDonald underground water service fittings, If you need odd ones, you can get them there. Don't forget to put the Stainless Steel stiffeners inside the pipe.0 -
I hate to be "that guy" who derails the post and I don't want to ask for price but can I get this cut to length and is the price for 100' gonna make me throw up? It looks like a great product. I have a customer who wants to move his wood boiler to his shop and it's about 100' away from the current location.Tom
Montpelier Vt0 -
This company will cut to length as specified. I'm in the Chicago area and got mine from Porter Pipe and Supply. The pipe and the fittings aren't cheap but nothing that will cause gastrointestinal problems. The heat shrink caps are another story.Steve Minnich0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
