Jomar Filter Ball Valve
Tinman
Member Posts: 2,808
Has anyone used this valve before? It's pictured bottom left. I thought I'd try it instead of a y-strainer. You close the valve, unscrew the hex plug, and remove/replace the strainer and only lose a few ounces of water/glycol mix in this snowmelt application.
Steve Minnich
I used them in the past. It is a very small capacity screen, they tend to plug, or reduce flow quickly.
Good for start ups, run for a day and remove the strained.Bob "hot rod" Rohr
Thanks Hot Rod.Steve Minnich0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
