Jomar Filter Ball Valve
Steve Minnich
Member Posts: 2,868
Has anyone used this valve before? It's pictured bottom left. I thought I'd try it instead of a y-strainer. You close the valve, unscrew the hex plug, and remove/replace the strainer and only lose a few ounces of water/glycol mix in this snowmelt application.
Steve Minnich
I used them in the past. It is a very small capacity screen, they tend to plug, or reduce flow quickly.
Good for start ups, run for a day and remove the strained.Bob "hot rod" Rohr
Living the hydronic dream0 -
Thanks Hot Rod.Steve Minnich0
