Expansion noise or water hammer?
Abracadabra
Member Posts: 1,949
Can't find any clues that would indicate water hammer, I'm inclined to think this is expansion noise. I've been there 3 times during the day, manually started a run cycle on the boiler, I get no noise whatsoever. Customer says it only happens in the middle of the night after a setback. Setback is only 4 degrees. 68 at night from 72 during day.
https://www.youtube.com/watch?v=xJJHnhfM-r4
https://www.youtube.com/watch?v=xJJHnhfM-r4 0
Tell him to have no setback for a while-68 degrees constant setting, and I am sure they will feel comfortable. Even 65 would work.--NBC0
Heh.. "customer" is the owner of the rental. video was taken by the tenant. I know for a fact that tenants in chicago don't appreciate 65 or even 68. I'll tell him to try no setback at 72 and see what happens. thx.0
Even though 65 seems chilly, the "feels like" temperature seems higher due to the radiant heat coming from the rads (assuming no drafty windows!).--NBC0
I like the plastic milk bottle bushing.
I agree with others, sounds like the pipe is rubbing against the floor. Can you look down around the pipe with a flashlight and see if it's rubbing on one side? if so just slide the radiator over to get the pipe off of the wood.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
