Christmas list
nicholas bonham-carter
Member Posts: 8,577
Since I have been a moderately good boy this year I am requesting the following items from Santa, either under the tree, or even better, on the boiler:
1. A wireless thermostat, with remote temperature sensors, able to connect with the boiler, either wirelessly, or through the house wiring (think old Radio Shack plug and talk intercoms). Some buildings have too much stone and brick to get a clear signal from one end to another. The sensors should be able to be averaged, or used singly as a high limit.
2. A piping arangement on the equalizer, and returns which acts as an oil trap (auto-skimmer). If every hour of firing, it separated out 1% of the surface oils, in a few weeks, the water would be clean. Piped in conjunction with the float type lwco, the oil would be emptied with every flush.
3. An idiot light for every safety on the boiler, to indicate which one is locking the burner out.
4. Main vents, with a visible open-closed indicator.
has anyone got some other items for his list?--NBC
Sounds reasonable to me....0
Wirelessly controlled radiator vents, tied into the aforementioned wireless thermostat, coupled with a sophisticated algorithm to allow the system to self-balance the venting rates to synchronize steam at the rads or allow for focusing heat in rooms needing heat on the fly.0
Good idea!
Let's hope the elves are starting their work right now.
I know that I will be paying particular attention to "Santa Tracker", on the NORAD radar system. Let's hope He doesn't get buzzed by those troublesome Russian Bombers, testing the system for accuracy, (just like Oresident Putin to Grinch up Christmas!--NBC0 -
Now here is the question I have. Does santa do the install or do you? I personally just want the "stuff" so I can do my own installation. Never know Santa might be a knucklehead.0
He's not a dead man but he is getting up there in years.nicholas bonham-carter said:No he is an expert, and a regular contributor here under an assumed name-beginning with "S"--NBC
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 987 Plumbing
- 389 Solar
