test ports on gas valve
zepfan
Member Posts: 456
in Gas Heating
Does anyone know where to get the fittings to check the pressures on these gas valves that have the very small test ports that you remove with a 3/32" allen wrench.The thread size is less then 1/16", and i can not find any thread by barbed fittings to check the incoming or manifold pressures.thanks to all.
thanks,i'll do that0
if its a female thread i use a 1/8" npt barbed fitting and push my manometer tube onto it0
Many gas valves manufactured in the last ten years don't have the 1/8" pipe tap. They simply have a tapered boss with a small screw inside. You open the screw about one turn to allow pressure to release around it and slip a hose directly over the boss. There is no adaptor needed. This is what the original question was about.shawnnolan said:if its a female thread i use a 1/8" npt barbed fitting and push my manometer tube onto it
I'm glad you're one of the few that actually checks manifold pressure. Most "techs" don't. Many don't even have a manometer or even know what one is.
Bob Boan
You can choose to do what you want, but you cannot choose the consequences.3 -
The Fieldpiece dual port manometer comes with 'adapters' for that style of gas valve. Unless I miss my guess, it's nothing more fancy than a few 3" pieces of 3/8 tubing & a set of large <-> small plastic hose barb adapters. But I really like the Fieldpiece, especially the new model with the built-in pump. Kind of hoping my current one breaks so I have a reason to upgrade.0
Sigh, and I always thought a manometer had fluid in it!0
When I convert Bryant furnaces to LP, I remove the 1/8” plug ( it’s a pain to get it out), I then spin in a nipple and 90 then finger tighten a barb fitting into the 90.
The nipple/90/male by barb setup is nice and fast, I use it all the time0 -
On mod cons, it's just like Ironman said. Loosen the screw just a little bit, put the boot of your manometer over the boss, and there's you have it. Quick and easy.Steve Minnich0
http://www.maxitrol.com/miscellaneous.html
As stated, more and more test ports cast into body of valve with captive screw. For inlet pressure, I use gas cocks with downstream 1/8" NPT plugged tap. Great for checking inlet pressure drop while firing.1 -
Steve Minnich0 -
I add a tee on the outside of the unit with a 1/4" branch after the gas stop. Put in a 1/4" brass plug. Keep a 1/4 x 1/8 bushing with the manometer to test gas pressure. Less things to take apart if checking inlet only.
Easier than digging around on the gas valve.
If you have ever had the Allen wrench strip out an aluminum plug it is a PIA.0
