Leak under water heater
Patchogue Phil_2
Member Posts: 312
Somebody will take that leek0
Jokes aside, if you know that the leak is not from the drain valve, then it looks like the tank has rusted through, and the water heater is due for replacement. How old is it? I see a display panel on it which makes it seem newish.--NBC0
And yes, leeks with a mustardy cheese sauce, wrapped around with slices of ham is a favorite of mine. In fact, I think leeks to be underestimated as a veg, and maybe a group could be formed to try and make everyone see how wonderful they can be!--NBC0
All jokes aside what kind of water heater is that!?
It looks like it has an exposed burner consisting of several burner tubes?
I prefer Leek and Potato soup. It just takes so long to make from scratch.0
Actually, the leek is not under nor from the water heater.0
Yes. it looks like you need water heater replacement. Would like to know the age and make of the water heater. Because it seems like it failed prematurely.
Leak under water heater means time to call water heater repair company like all week heating-4
Seems like a lot of people didn't get it.
time to build an Ark, and make some soup
and make some soup0
This is company that uses a phone bank in Bergen County btw...0
- 87K THE MAIN WALL
- 58 Biomass
- 116 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
